Introduction
Replace a faulty Bluetooth antenna to regain Bluetooth range.
Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
Lift the Bluetooth board off the internal frame and use the flat end of a spudger to pry the Bluetooth antenna cable connector up off the Bluetooth board.
Pull the Bluetooth antenna cable out from underneath all the cables connected to the interconnect board.
Remove the Bluetooth antenna by pushing up on both sides of the board as close to the center post as possible.
Remove the Bluetooth antenna from the internal frame.
