Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
Parts
No parts specified.
  1. Place your thumbs in the depressions cut into the bottom cover. Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Lift the fan out of the mini for enough clearance to access its connector. Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board. Do not pry at the socket, or you may rip it from the logic board.
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Lift the cowling from the end nearest the antenna plate.
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 5,678
