Introduction
Use this guide to replace the antenna plate that serves as a mount for the antenna as well as the hard drive.
Place your thumbs in the depressions cut into the bottom cover.
Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
Remove the bottom cover and set it aside.
Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Lift the fan out of the mini for enough clearance to access its connector.
Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
Remove the fan.
Lift the cowling from the end nearest the antenna plate.
Rotate the cowling away from the outer case and remove it from the mini.
Remove the following screws securing the antenna plate to the mini:
Two 6.6 mm T8 Torx screws
Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
When putting back together:
Slightly lift the antenna plate from the end closest to the RAM.
Carefully pull the antenna plate away from the circular rim of the outer case.
Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
