Mac Mini Mid 2010 Logic Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Mini Mid 2010 Logic Board Replacement, Logic Board: step 1, image 1 of 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  2. Mac Mini Mid 2010 Logic Board Replacement: step 2, image 1 of 2 Mac Mini Mid 2010 Logic Board Replacement: step 2, image 2 of 2
    • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
  3. Mac Mini Mid 2010 Logic Board Replacement: step 3, image 1 of 2 Mac Mini Mid 2010 Logic Board Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
  4. Mac Mini Mid 2010 Logic Board Replacement: step 4, image 1 of 1
    • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
  5. Mac Mini Mid 2010 Logic Board Replacement: step 5, image 1 of 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
  6. Mac Mini Mid 2010 Logic Board Replacement: step 6, image 1 of 3 Mac Mini Mid 2010 Logic Board Replacement: step 6, image 2 of 3 Mac Mini Mid 2010 Logic Board Replacement: step 6, image 3 of 3
    Tool used on this step:
    Mac mini Logic Board Removal Tool
    Buy
    • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
    • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
  7. Mac Mini Mid 2010 Logic Board Replacement: step 7, image 1 of 1
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
  8. Mac Mini Mid 2010 Logic Board Replacement: step 8, image 1 of 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use a pair of tweezers to disconnect the power cable from the logic board.
    • Pull the power cable connector toward the optical drive opening.
  9. Mac Mini Mid 2010 Logic Board Replacement: step 9, image 1 of 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,622
