Installing Mac Mini Mid 2010 AirPort/Bluetooth Board
  1. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Bottom Cover: step 1, image 1 of 2 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Bottom Cover: step 1, image 2 of 2
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
  2. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 2, image 1 of 1
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Fan: step 3, image 1 of 1
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 4, image 1 of 1
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • If the fan doesn't separate from the standoff screw with a moderate amount of force, you can use a T6 Torx driver to simply remove this screw.
  5. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 5, image 1 of 1
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
    • Remove the fan.
  6. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Cowling: step 6, image 1 of 1
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 7, image 1 of 1
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Antenna Plate: step 8, image 1 of 1
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 or T9 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either will work)
  9. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 9, image 1 of 2 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 9, image 2 of 2
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate straight away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 10, image 1 of 1
    • Use the tip of a spudger to carefully pry the antenna connector up off the AirPort/Bluetooth board.
  11. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 11, image 1 of 1
    • Remove the antenna plate from the mini.
  12. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Logic Board: step 12, image 1 of 1
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  13. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 13, image 1 of 2 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 13, image 2 of 2
    • Carefully pull the wires for both hard drive thermal sensors upward to lift their connectors up and out of the sockets on the logic board.
  14. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 14, image 1 of 2 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 14, image 2 of 2
    • Use the flat end of a spudger to pry both the hard drive and optical drive connectors up out of their sockets on the logic board.
  15. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 15, image 1 of 1
    • To disconnect the optical drive thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
  16. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 16, image 1 of 1
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
  17. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 17, image 1 of 3 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 17, image 2 of 3 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 17, image 3 of 3
    Tool used on this step:
    Mac mini Logic Board Removal Tool
    Buy
    • To remove the logic board, two cylindrical rods must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert a Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the outer case below the logic board before proceeding.
    • If you don't have a Logic Board Removal Tool handy, you can use two tools having a maximum diameter of 2.5 mm instead. Just insert one into each of the highlighted holes.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case. Remove the Mac mini Logic Board Removal tool.
  18. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 18, image 1 of 1
    • Simultaneously push the two plastic clips on the far left and right sides of the I/O board toward the middle of the I/O board and pull the I/O board away from the outer case.
  19. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 19, image 1 of 1
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use a pair of tweezers to disconnect the power cable from the logic board.
    • Pull the power cable connector toward the optical drive opening.
  20. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 20, image 1 of 1
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  21. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, Speaker: step 21, image 1 of 1
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 4.2 mm T6 Torx
    • One 3.7 mm T6 Torx
  22. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 22, image 1 of 1
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
  23. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, AirPort/Bluetooth Board: step 23, image 1 of 2 Installing Mac Mini Mid 2010 AirPort/Bluetooth Board, AirPort/Bluetooth Board: step 23, image 2 of 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth board.
  24. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 24, image 1 of 1
    • Use your spudger to help disconnect the AirPort/Bluetooth ribbon cable from its socket on the AirPort/Bluetooth board.
  25. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 25, image 1 of 1
    • Remove the three 2.6 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  26. Installing Mac Mini Mid 2010 AirPort/Bluetooth Board: step 26, image 1 of 1
    • Remove the AirPort/Bluetooth board from the logic board.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 11,660
