Mac Pro Late 2013 Power Supply Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Pro Late 2013 Power Supply Assembly Replacement, Power Supply Assembly: step 1, image 1 of 1
    • Flip the Mac Pro back over and set it gently on a flat surface.
    • We recommend laying the Mac Pro on the corner of the heat sink and the two standoff screw posts that attach to the interconnect board.
  2. Mac Pro Late 2013 Power Supply Assembly Replacement: step 2, image 1 of 2 Mac Pro Late 2013 Power Supply Assembly Replacement: step 2, image 2 of 2
    • Remove the two 3.6 mm T5 Torx screws from the sides of the power supply cage (one on each side).
  3. Mac Pro Late 2013 Power Supply Assembly Replacement: step 3, image 1 of 1
    • Remove the power supply cage from the top of the power supply.
    • By removing this cage, you are exposing internal components of the power supply. Be very careful not to touch any of the power supply components or circuitry.
    • Be careful not to drop any screws or tools into the power supply, as this may damage the power supply.
  4. Mac Pro Late 2013 Power Supply Assembly Replacement: step 4, image 1 of 1
    • Remove the four 5.5 mm T8 Torx screws securing the power supply assembly to the Mac Pro.
  5. Mac Pro Late 2013 Power Supply Assembly Replacement: step 5, image 1 of 1
    • Remove the power supply assembly from the Mac Pro.
Andrew Optimus Goldheart
502,810 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,817 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 92
