Mac Mini Mid 2011 Hard Drive Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Mac Mini Mid 2011 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Mac Mini Mid 2011 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Pull the hard drive away from the front edge of the mini and remove it from the outer case.
    • During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
    • There are two pairs of holes in the case. Insert the pins into the holes closest to the bottom of the case.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,024
