MSI GS60 6QE GHOST PRO 4K Battery Replacement
  1. MSI GS60 6QE GHOST PRO 4K Battery  Replacement, Battery: step 1, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement, Battery: step 1, image 2 of 2
    • Remove the eleven 5mm screws with a Phillips #0 bit.
    • Remove the four 2.5mm screws with a Phillips #0 bit.
  2. MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 2, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 2, image 2 of 2
    • After opening the bottom plate, locate the battery and the battery connection.
  3. MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 3, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 3, image 2 of 2
    • Unplug the battery connection carefully from the motherboard, and remove the old battery.
5 other people completed this guide.
Azher Hamid
378 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Nance Fall 2017 Member of USF Tampa, Team S1-G4, Nance Fall 2017
USFT-NANCE-F17S1G4
3 Members
5 Guides authored
One Comment
The screws on corners doesnt have the same length. The Guide is wrong carefull!
Hüseyin Temizkan - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 24
All Time: 5,594
