MSI GE70 2PE Apache Pro Touchpad Replacement
  1. MSI GE70 2PE Apache Pro Touchpad Replacement, Battery: step 1, image 1 of 1
    • Turn over the laptop so the battery compartment is facing up.
  2. MSI GE70 2PE Apache Pro Touchpad Replacement: step 2, image 1 of 1
    • Push the right latch all the way to the right until it clicks into place.
  3. MSI GE70 2PE Apache Pro Touchpad Replacement: step 3, image 1 of 1
    • Pull and hold the left latch.
  4. MSI GE70 2PE Apache Pro Touchpad Replacement: step 4, image 1 of 1
    • Pry the battery upward using the indent.
  5. MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 3 of 3
    • Continue to pull the battery until it is free of the casing.
  6. MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 3 of 3
    • Remove the six 5.5mm screws by using a Phillips #1 screwdriver.
    • Pry the door off using a plastic opening tool.
  7. MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 3 of 3
    • Remove the five 3.5mm screws by using a Phillips #1 screwdriver.
  8. MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 3 of 3
    • Remove the twenty-one 5.5mm screws by using a Phillips #1 screwdriver.
  9. MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 3 of 3
    • Disconnect the power, mic, and LVDS cables.
  10. MSI GE70 2PE Apache Pro Touchpad Replacement: step 10, image 1 of 1
    • Turn over the laptop so the screen is open and keyboard is exposed.
  11. MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 3 of 3
    • Remove the two 5.5mm screws by using a Phillips #1 screwdriver.
  12. MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 3 of 3
    • Disconnect the touchpad, touchpad button, and power board connections.
  13. MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 3 of 3
    • Using the plastic opening tool, pry open the computer case.
  14. MSI GE70 2PE Apache Pro Touchpad Replacement: step 14, image 1 of 2 MSI GE70 2PE Apache Pro Touchpad Replacement: step 14, image 2 of 2
    • Turn the panel over so that the internals are facing upward.
  15. MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 3 of 3
    • Remove the five 2.5mm screws by using a Phillips #1 screwdriver.
  16. MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 3 of 3
    • Using the plastic opening tool, pry the touchpad off and remove it.
2 Comments
Do you know where the replacement touchpads for MSI laptops can be purchased? The touchpad getting stuck seems to be a common issue on their forums
Connor D - Reply
i looking for touchpad part also…
Rafał Pawlak -
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 4,048
