MSI GE62 6QF Apache Pro RAM Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
2,759
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove the RAM out of your device.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
    1. MSI GE62 6QF Apache Pro  RAM Replacement, Optical Drive: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the 5mm screw securing the optical drive to the bottom case.
      Ask FixBot
    2. MSI GE62 6QF Apache Pro  RAM Replacement: step 2, image 1 of 1
      • Slide Optical Drive out of the computer.
      Ask FixBot
    1. MSI GE62 6QF Apache Pro  RAM Replacement, Bottom Case: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the fourteen 5mm screws on the back of the laptop.
      • One of these screws is hidden under a sticker.
      Ask FixBot
    2. MSI GE62 6QF Apache Pro  RAM Replacement: step 4, image 1 of 3 MSI GE62 6QF Apache Pro  RAM Replacement: step 4, image 2 of 3 MSI GE62 6QF Apache Pro  RAM Replacement: step 4, image 3 of 3
      • Remove the three PH #0 2mm screws that were hidden underneath the optical drive.
      Ask FixBot
    3. MSI GE62 6QF Apache Pro  RAM Replacement: step 5, image 1 of 2 MSI GE62 6QF Apache Pro  RAM Replacement: step 5, image 2 of 2
      • Use an opening tool to run along the seam of the case where the upper and bottom case meet.
      • Pry the bottom case and remove from the upper part.
      Ask FixBot
    1. MSI GE62 6QF Apache Pro  RAM Replacement, Battery: step 6, image 1 of 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: step 6, image 2 of 3 MSI GE62 6QF Apache Pro  RAM Replacement, Battery: step 6, image 3 of 3
      • Remove the single PH #0 5mm screw holding the battery pack in place.
      • Remove the battery by sliding it away from the computer.
      Ask FixBot
    1. MSI GE62 6QF Apache Pro  RAM Replacement, RAM: step 7, image 1 of 2 MSI GE62 6QF Apache Pro  RAM Replacement, RAM: step 7, image 2 of 2
      • Pull the metal tabs that hold the RAM in place away horizontally from the RAM stick, and slide the RAM out of the socket.
      • Repeat the same steps for the other RAM stick.
      Ask FixBot
Juan Erquiaga
107 Reputation
1 Guide authored
USF Tampa, Team S2-G3, Passmore Fall 2017 Member of USF Tampa, Team S2-G3, Passmore Fall 2017
USFT-PASSMORE-F17S2G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 2,759
