MNT Pocket Reform Thermal Pad Replacement
  1. MNT Pocket Reform Thermal Pad Replacement, Remove the top cover: step 1, image 1 of 2 MNT Pocket Reform Thermal Pad Replacement, Remove the top cover: step 1, image 2 of 2
    • Place the laptop on your work surface so the top cover with the MNT logo is facing up.
    • Use a Phillips screwdriver to remove the seven 4.8 mm‑long screws securing the top cover.
  2. MNT Pocket Reform Thermal Pad Replacement: step 2, image 1 of 3 MNT Pocket Reform Thermal Pad Replacement: step 2, image 2 of 3 MNT Pocket Reform Thermal Pad Replacement: step 2, image 3 of 3
    • The top cover is made of printed circuit board (PCB) material. Press gently but firmly near an edge when applying the suction handle to avoid breaking the cover.
    • Apply a suction handle to the top cover.
    • Use the suction handle to lift the top cover off of the laptop.
    • Alternatively, you can use a thin prying tool to lift the cover, or tilt the laptop until the cover falls out.
    • There's a thermal pad between the top cover and the processor that may stick to the top cover during removal.
  3. MNT Pocket Reform Thermal Pad Replacement, Remove the thermal pad and residue: step 3, image 1 of 3 MNT Pocket Reform Thermal Pad Replacement, Remove the thermal pad and residue: step 3, image 2 of 3 MNT Pocket Reform Thermal Pad Replacement, Remove the thermal pad and residue: step 3, image 3 of 3
    • Use tweezers or your fingers to peel up the old thermal pad.
    • The thermal pad may be stuck to either the processor or the top cover.
    • Use high concentration (greater than 90%) isopropyl alcohol and a coffee filter or a lint-free cloth to clean the processor and the area of the top cover that will contact the thermal pad.
    • Clean both the processor and the top cover even if it's a new part.
  4. MNT Pocket Reform Thermal Pad Replacement, Prepare the thermal pad: step 4, image 1 of 2 MNT Pocket Reform Thermal Pad Replacement, Prepare the thermal pad: step 4, image 2 of 2
    • Cut the thermal pad to a size of about 2 cm by 2 cm.
  5. MNT Pocket Reform Thermal Pad Replacement, Apply the thermal pad: step 5, image 1 of 3 MNT Pocket Reform Thermal Pad Replacement, Apply the thermal pad: step 5, image 2 of 3 MNT Pocket Reform Thermal Pad Replacement, Apply the thermal pad: step 5, image 3 of 3
    • Peel the backing off of one side of the thermal pad.
    • Apply the thermal pad to the processor, which is the large chip on the processor module that sits on top of the motherboard.
    • Peel the backing off of the other side of the thermal pad.
Spencer Pennington
22,776 Reputation
123 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,768 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 172
