Introduction
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom outer mesh.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
2 Comments
You know where to buy a replacement mesh in custom colors
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Pry all the way around with the tool as there are “clips” that hold the cap in place all around beneath the cap. Avoid trying to “pull the lid open” from the opening of a half opened lid.
Jamin Hu - Reply
Stop! Before you proceed, notice the comments at the end of the guide. You don't have to take apart both sides or remove the mesh fabric. Remove just the bottom cap (with the aux/charge plug).
Then carefully remove the glue securing the circuit board on the sides and gently pull the board out to reveal the battery under it.
Caleb Kelsay - Reply
FWIW I had no luck opening these caps with the tools I bought on iFixit (plastic pry bar, metal Jimmy). I had a lot more luck using the flat edge of a butter knife! (it still took lots of work on my UE Megaboom 3)
Travis Taylor - Reply
