Introduction
This guide will assist you with the removal and replacement of the Logitech UE Megaboom motherboard.
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
Remove inner plastic gasket on circuit board.
Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
Insert a opening tool between the grating and the body of the speaker
Pry up allowing the tabs to pop out of place.
Apply the same procedure to the grating covering the second speaker.
Use a opening tool to push the thin metal rod located on the side of the speaker out.
Using needle nose pliers grasp the rod and pull the rod out of the speaker until fully removed.
Remove the remaining three rods.
Insert a opening tool between the speaker and the base
Pry up allowing the speaker tabs to pop out of place
Find and disconnect the wire from the motherboard by pulling in an upward motion.
Apply the same procedure to the second speaker.
