1. Turn the keyboard. Back facing up
    • Turn the keyboard. Back facing up
    • Remove the 4 rubers hiding 4 screws
    • Unscrew the 8 visible screws
    • Unclip the two plastic side of the keyboard
    • Careful the maximum opening distance range is limited by an internal connection. Open gentely
  2. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
    • Unplug the connection avoid the separation of the two plastic parts.
    • Unplug the batterie connector from the base side
    • You can now separate the two part of the keyboard
    • Repair the welding of the micro usb connector
    That USB connector will not be fixed by somebody with a simple soldering iron. It has the smallest soldering points, and I think it’s actually done with the PCB removed.
    psilan - Reply
    • Plug the battery connector
    • Plug the connection from the upper part of the keyboard
    • Reassemble both keyboard part
    • Clip them together
    • Screws the 8 screws
    • Stick the 4 rubers at their respectives positions
mathieubernou
137 Reputation
1 Guide authored
One Comment
Repair the welding of the micro usb connector . hi will you please tell me how you soldered it ?
Any help in this will be much appreciated
Healthy & Yummy - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 81
All Time: 1,671
