Logitech Harmony Touch Buttons Replacement
  1. Logitech Harmony Touch Buttons Replacement, Buttons: step 1, image 1 of 3 Logitech Harmony Touch Buttons Replacement, Buttons: step 1, image 2 of 3 Logitech Harmony Touch Buttons Replacement, Buttons: step 1, image 3 of 3
    • Open the latch that accesses the charging port.
    • Remove the black sticker and the screw with the Phillips #0 Screwdriver.
    • Take the plastic opening tool and run it down the side of the remote to open the case.
    • While doing this step, three wires connect the two pieces, be sure not to rip them out.
    • Detach the white clamp to disconnect the case from the motherboard partially.
  2. Logitech Harmony Touch Buttons Replacement: step 2, image 1 of 3 Logitech Harmony Touch Buttons Replacement: step 2, image 2 of 3 Logitech Harmony Touch Buttons Replacement: step 2, image 3 of 3
    • Peel back the thin yellow plastic film.
    • Detach the clip found underneath the film.
    • Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
  3. Logitech Harmony Touch Buttons Replacement: step 3, image 1 of 3 Logitech Harmony Touch Buttons Replacement: step 3, image 2 of 3 Logitech Harmony Touch Buttons Replacement: step 3, image 3 of 3
    • Next, carefully remove the motherboard from the top piece of the case.
    • The motherboard is connected to the bottom part of the case.
    • You should now be able to access all the buttons and remove them from the case.
  4. Logitech Harmony Touch Buttons Replacement: step 4, image 1 of 2 Logitech Harmony Touch Buttons Replacement: step 4, image 2 of 2
    • Remove the buttons from the case.
Nicholas Townsend
264 Reputation
2 Guides authored
USF Tampa, Team S4-G2, Eyestone Fall 2017 Member of USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 23
All Time: 1,306
