Logitech Harmony 950 Battery Replacement
  1. Logitech Harmony 950 Battery Replacement, Battery: step 1, image 1 of 2 Logitech Harmony 950 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure the remote control is powered off before starting.
    • Use the Opening Tool to open the port cover at the bottom of the remote control.
    • Bend the cover back to gain easy access to the screws.
  2. Logitech Harmony 950 Battery Replacement: step 2, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 2, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 2, image 3 of 3
    • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
    • Pull the bottom cover off of the remote control.
  3. Logitech Harmony 950 Battery Replacement: step 3, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 3, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 3, image 3 of 3
    • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
    • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
  4. Logitech Harmony 950 Battery Replacement: step 4, image 1 of 3 Logitech Harmony 950 Battery Replacement: step 4, image 2 of 3 Logitech Harmony 950 Battery Replacement: step 4, image 3 of 3
    • Use the Opening Tool to lift the battery out of the case.
    • Gently pull the cable out of the socket to unplug the battery.
    • Be careful not to damage any part of the remote when pulling the cable out.
7 other people completed this guide.
Blake Sanborn
534 Reputation
3 Guides authored
USF Tampa, Team S2-G2, Passmore Fall 2017 Member of USF Tampa, Team S2-G2, Passmore Fall 2017
USFT-PASSMORE-F17S2G2
4 Members
4 Guides authored
2 Comments
And where to buy these batteries?
Rene A - Reply
Still no batteries for this unit? Maybe Amazon?
Dan - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 41
All Time: 4,761
