Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix
Views: 2.1K
View statistics:
Past 24 Hours:
26
Past 7 Days:
132
Past 30 Days:
495
All Time:
2,075
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The easiest way to check whether the mouse buttons are no longer working reliably is to try selecting multiple files on the desktop using the drag-and-select function.
If files are accidentally moved during this process, or there are unintended double-clicks, the microswitch is likely damaged or worn out.
Parts
Tools
    1. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Remove the skates: step 1, image 1 of 1
      • Turn off the mouse using the switch on the underside.
      • Remove the marked stickers/skates with tweezers or a scalpel.
      • If necessary, you can also pierce through the top sticker.
      Ask FixBot
    2. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Remove loose parts: step 2, image 1 of 2 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Remove loose parts: step 2, image 2 of 2
      • Remove the side buttons or the cover on the sides.
      • Remove the optional weight or the wireless charging puck.
      Ask FixBot
    3. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the bottom screws: step 3, image 1 of 2 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the bottom screws: step 3, image 2 of 2
      • Remove the 6 highlighted screws with a J00 Phillips driver bit.
      • Remove the Torx screw with the corresponding driver bit.
      Ask FixBot
    4. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the internal cabling: step 4, image 1 of 1
      • Lift the white tab on the ribbon cable socket. Then, you can carefully pull the cable out of the socket.
      • Disconnect these cable connections and set the lower case aside.
      • Remove the upper cover from the lower case. Note that there are cables on the back of the mouse.
      Ask FixBot
    5. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Remove the replacement battery: step 5, image 1 of 1
      Tool used on this step:
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Loosen the adhesive using either isopropyl alcohol or targeted heat.
      • Caution: When prying out the replacement battery, be careful not to damage it. For this, it is best to use an iFixit opening pick.
      • Try to insert the opening pick into the battery compartment from the front of the mouse.
      Ask FixBot
    6. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Releasing modular components: step 6, image 1 of 1
      • From this point on, you will only need the J00 Phillips driver bit.
      • Remove the ten screws marked in red.
      Ask FixBot
    7. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the hidden screw: step 7, image 1 of 1
      • Now remove the screw under the battery compartment and set it aside separately.
      • Attention: Other screws will not fit into this thread.
      Ask FixBot
    8. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the top cover: step 8, image 1 of 3 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the top cover: step 8, image 2 of 3 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the top cover: step 8, image 3 of 3
      • The tabs on the top cover can get caught during removal. Pull the cover carefully toward the back and up, maneuvering it out with a slight pull.
      • Set the cover aside.
      Ask FixBot
    9. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the mouse button cover: step 9, image 1 of 1
      • Rotate the mouse buttons out to the side.
      • Then turn the remaining mouse assembly over, remove the four marked screws on the mouse buttons, and set them aside.
      Ask FixBot
    10. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the side magnets: step 10, image 1 of 2 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the side magnets: step 10, image 2 of 2
      • Release the magnetic side button covers. Use the existing play to carefully maneuver the covers out.
      Ask FixBot
    11. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the DPI cover: step 11, image 1 of 2 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the DPI cover: step 11, image 2 of 2
      • Move the cover backward and upward as shown in the image so that it does not get caught on the DPI buttons.
      • Remove the four screws at the front of the mouse.
      • Remove the cover for the DPI buttons and the flywheel lock.
      Ask FixBot
    12. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the mouse buttons: step 12, image 1 of 2 Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Release the mouse buttons: step 12, image 2 of 2
      • Fold the cover back, being careful not to kink or tear the ribbon cable.
      • Attention: The ribbon cable is attached to the PCB. Do not kink or damage it.
      • Remove the four screws marked in red on the mouse buttons.
      Ask FixBot
    13. Logitech G903 Left/Right Mouse Button Replacement – Double-Click Fix, Replacing a mouse switch: step 13, image 1 of 1
      • Now, disconnect the socket of the corresponding mouse switch.
      Ask FixBot
      • After replacing the mouse switches, follow the guide in reverse to reassemble your device. Only reuse the battery and skates if they are undamaged.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Annika is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Eggie IV
239 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 26
Past 7 Days: 132
Past 30 Days: 495
All Time: 2,075
