Logitech G515 Lightspeed TKL Battery Replacement
  1. Logitech G515 Lightspeed TKL Battery Replacement, Prepare your keyboard for disassembly: step 1, image 1 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Prepare your keyboard for disassembly: step 1, image 2 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Prepare your keyboard for disassembly: step 1, image 3 of 3
    • Slide the power switch on the top edge of the keyboard to the OFF position.
    • A red indicator should be visible beneath the switch.
    • Unplug all cables from your keyboard.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface might scratch the keyboard, place a soft towel under it.
    Ask FixBot
  2. Logitech G515 Lightspeed TKL Battery Replacement, Remove the USB receiver: step 2, image 1 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the USB receiver: step 2, image 2 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the USB receiver: step 2, image 3 of 3
    • If you have a USB receiver stored in the battery cover compartment, use your finger to slide it out and remove it.
    Ask FixBot
  3. Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery cover screws: step 3, image 1 of 2 Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery cover screws: step 3, image 2 of 2
    • Use a Phillips screwdriver to remove the two 6.7 mm‑long screws securing the battery cover.
    Ask FixBot
  4. Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery cover: step 4, image 1 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery cover: step 4, image 2 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery cover: step 4, image 3 of 3
    • Insert your finger in the USB receiver compartment on the battery cover and lift to remove it.
    Ask FixBot
  5. Logitech G515 Lightspeed TKL Battery Replacement, Disconnect the battery: step 5, image 1 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Disconnect the battery: step 5, image 2 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use a pair of angled tweezers to firmly grip the battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm grip.
    • Gently rock the connector side‑to‑side and slide it straight out of the socket.
    Ask FixBot
  6. Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery: step 6, image 1 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery: step 6, image 2 of 3 Logitech G515 Lightspeed TKL Battery Replacement, Remove the battery: step 6, image 3 of 3
    Tool used on this step:
    Tesa 61395 Tape
    $2.95
    Buy
    • Make sure you push your tool underneath the battery and not into it. Don't bend or deform the battery.
    • Slide the flat end of a spudger under the left side of the battery and gently lift to separate the adhesive securing it to the keyboard.
    • If the battery is stuck or starts to bend, apply a few drops of high‑concentration isopropyl alcohol (>90%) to its edge and slightly tilt the keyboard so the alcohol flows under the battery. Wait one minute for the alcohol to soften the adhesive and try again.
    • Remove the battery.
    • During reassembly:
    • Remove the old adhesive from the battery recess.
    • Apply a strip of thin, double‑sided tape to the battery recess, where the old adhesive was.
    • Lay the battery into its recess so the cable is on the side with the connector and press the battery into place.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
195,723 Reputation
1,243 Guides authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 35
Past 30 Days: 215
All Time: 981
