Logic Board Disconnection
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Logic Board Disconnection, Disconnect the logic board: step 1, image 1 of 2 Logic Board Disconnection, Disconnect the logic board: step 1, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Remove the trackpad connector bracket.
  2. Logic Board Disconnection: step 2, image 1 of 2 Logic Board Disconnection: step 2, image 2 of 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  3. Logic Board Disconnection: step 3, image 1 of 3 Logic Board Disconnection: step 3, image 2 of 3 Logic Board Disconnection: step 3, image 3 of 3
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  4. Logic Board Disconnection: step 4, image 1 of 2 Logic Board Disconnection: step 4, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  5. Logic Board Disconnection: step 5, image 1 of 2 Logic Board Disconnection: step 5, image 2 of 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  6. Logic Board Disconnection: step 6, image 1 of 3 Logic Board Disconnection: step 6, image 2 of 3 Logic Board Disconnection: step 6, image 3 of 3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  7. Logic Board Disconnection: step 7, image 1 of 1
    • Peel back the black tape covering the fan cable connector.
  8. Logic Board Disconnection: step 8, image 1 of 3 Logic Board Disconnection: step 8, image 2 of 3 Logic Board Disconnection: step 8, image 3 of 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  9. Logic Board Disconnection: step 9, image 1 of 2 Logic Board Disconnection: step 9, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  10. Logic Board Disconnection: step 10, image 1 of 3 Logic Board Disconnection: step 10, image 2 of 3 Logic Board Disconnection: step 10, image 3 of 3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  11. Logic Board Disconnection: step 11, image 1 of 2 Logic Board Disconnection: step 11, image 2 of 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  12. Logic Board Disconnection: step 12, image 1 of 2 Logic Board Disconnection: step 12, image 2 of 2
    • Use the flat end of a spudger to pry up the display cable connector.
Adam O'Camb
196,083 Reputation
416 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 116
