Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Replacement
  1. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Turn the device over so that the base is facing up.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Replacement: step 2, image 1 of 1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need to reapply glue to the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Replacement: step 3, image 1 of 2 Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Replacement: step 3, image 2 of 2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
Nick Kaprielian
531 Reputation
4 Guides authored
Cal Poly, Team 17-3, Forte Winter 2014 Member of Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 734
