Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Lifebook E736 HDD or SSD Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
27
Past 30 Days:
103
All Time:
647
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
      • To prevent injury to the operator or damage to the device, you must remove the power source.
      • Disconnect the AC cable from the computer.
      • Close the computer and turn it over.
      • Turn the switch marked with the number "1" and a padlock icon to the left.
      • While pushing the tab marked "2 HOLD" toward you, lift the tab marked "3 PULL BATTERY UP" to initiate battery removal.
      Ask FixBot
      • Locate the cover marked with a symbol that looks like a bracket (「 ).
      • Use a #2 Phillips screwdriver to remove the screw from the cover.
      • Slide the old HDD or SSD to the left to disconnect it from the device.
      • Lift the old HDD or SSD out and remove it.
      Ask FixBot
      • Insert the new HDD or SSD into the slot. Be careful not to damage the slot.
      Ask FixBot
      • Return the battery to its original position. Press the battery into place by following the reverse of step 2.
      • Make sure the switch labeled "1" is in the right position. Otherwise, the battery may detach during use.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
Author
with
KASAI Toushi
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 103
All Time: 647
