Lenovo Yoga 2 Pro SSD Replacement
  1. Lenovo Yoga 2 Pro SSD Replacement, SSD: step 1, image 1 of 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro SSD Replacement: step 2, image 1 of 1
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro SSD Replacement: step 3, image 1 of 1
    • Navigate to the top right corner of the laptop and locate the solid state drive next to the fan.
    • Using a Phillips #00 screwdriver, remove the one 3/16” screw from the top left corner of the solid state drive.
    • The solid state drive will lift up after you remove the screw.
  4. Lenovo Yoga 2 Pro SSD Replacement: step 4, image 1 of 2 Lenovo Yoga 2 Pro SSD Replacement: step 4, image 2 of 2
    • To remove the solid state drive, gently slide it away from the battery and towards the hinges.
Thomas Simko
2,511 Reputation
5 Guides authored
Cal Poly, Team 12-14, Maness Fall 2015 Member of Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Members
12 Guides authored
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 104
All Time: 32,849
