Lenovo V15-ADA Hard Disk Drive (HDD) Replacement
    1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: step 1, image 1 of 2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Back Panel Assembly: step 1, image 2 of 2
      • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
      • M2.5 × 7 mm, Phillips-head (6) (RED circles)
      • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
      • The red circles show the longer screws, and the orange circles show the shorter screws.
      • Keep your screws organized. They’re different lengths and must go back in their original positions.
      Ask FixBot
    2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 2, image 1 of 2 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 2, image 2 of 2
      • After removing all ten screws, use a plastic spudger to separate the bottom cover from the laptop.
      • Gently slide the tool around the edges until the clips begin to release.
      • Once all the clips are loose, lift the cover off and set it aside.
      • The Wi-Fi card is located near one corner of the motherboard. It has two antenna wires connected to it (one black and one gray).
      Ask FixBot
    1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: step 3, image 1 of 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: step 3, image 2 of 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Battery: step 3, image 3 of 3
      • To start the removal of the battery, disconnect the ribbon cable connecting the battery to the computer.
      Ask FixBot
    2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 4, image 1 of 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 4, image 2 of 3 Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 4, image 3 of 3
      • The battery is held in place by 3 screws. Use the Phillips #0 screwdriver to remove the screws that secure the battery.
      • M2 × 6 mm, Phillips-head, nylok-coated (3)
      Ask FixBot
    3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 5, image 1 of 1
      • Remove the battery from the device after completing steps 1 and 2.
      Ask FixBot
    1. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement, Hard-Disk Drive (HDD): step 6, image 1 of 1
      • Attach a PH0 head onto the screwdriver and remove screw. (M2 × 6 mm, Phillips-head, nylok-coated)
      Ask FixBot
    2. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 7, image 1 of 1
      • Grasp the hard drive and lift up.
      Ask FixBot
    3. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 8, image 1 of 1
      • Pull the hard drive from its port.
      Ask FixBot
    4. Lenovo V15-ADA Hard Disk Drive (HDD) Replacement: step 9, image 1 of 1
      • The hard drive has been successfully taken out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 73
All Time: 1,280
