Lenovo V14-ADA Screen Replacement
  1. Lenovo V14-ADA Screen Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down.
  2. Lenovo V14-ADA Screen Replacement: step 2, image 1 of 1
    • Remove all ten 5 mm screws from the back panel using a JIS #0 screwdriver.
  3. Lenovo V14-ADA Screen Replacement: step 3, image 1 of 2 Lenovo V14-ADA Screen Replacement: step 3, image 2 of 2
    • Place the Jimmy in the small crack between the back panel and the keyboard and push down.
    • Repeat this until the panel pops off.
  4. Lenovo V14-ADA Screen Replacement, Battery: step 4, image 1 of 2 Lenovo V14-ADA Screen Replacement, Battery: step 4, image 2 of 2
    • Remove the four 3 mm screws surrounding the battery using a JIS #0 screwdriver.
    • Slightly pull on the black wire connector to unplug the battery.
    • Lift up the battery to remove it from the laptop.
  5. Lenovo V14-ADA Screen Replacement, Screen: step 5, image 1 of 3 Lenovo V14-ADA Screen Replacement, Screen: step 5, image 2 of 3 Lenovo V14-ADA Screen Replacement, Screen: step 5, image 3 of 3
    • Remove the four 3 mm screws on the hinges on both sides of the back of the laptop.
    • Use the Jimmy to pop the surrounding screen bezel off.
  6. Lenovo V14-ADA Screen Replacement: step 6, image 1 of 2 Lenovo V14-ADA Screen Replacement: step 6, image 2 of 2
    • Remove the two 3 mm screws at the top two corners of the screen using a JIS #0 screwdriver.
  7. Lenovo V14-ADA Screen Replacement: step 7, image 1 of 1
    • Remove the screen from the laptop.
Samaya Roukoz
253 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 22
All Time: 496
