Locate the two switches that lock the battery.
Then push the left switch outward into the "unlocked" position.
This is a rechargeable Li-Ion battery that has a capacity of 4400 mAh, if you have the 6 cell model.
Remove the two J00 screws on the backside.
it's only necessary to remove two of the ten screws (the ones marked with a keyboard icon.)
Tank You Mariska Gramlow and Thank You mats cronqvist!
Using the Metal Spudger, place between the trackpad and the keyboard and lift up to remove the keyboard and trackpad.
Pull keyboard towards yourself.
Grab the tab on the ribbon wire, pull off to release the keyboard.
Pull keyboard towards yourself exposing the ribbon wire that attaches it.
Grab the tab on the ribbon wire and pull up to release.
Grab new keyboard and clamp the ribbon into place.
Gently push the sides of keyboard into place.
Keyboard is now replaced and ready for use.
You only need to remove two screws and then gently push(or pry) the keyboard *away* from you, then up.
The correct 2 screws are labeled on the bottom with two tiny engraved icons. (The icons look like a keyboard)
4 other people completed this guide.
2 Comments
this is an absolutely awful guide...do not unscrew all those screws and do NOT use a metal spludger unless you want chips of plastic flying everywhere.
Jesus.
