Lenovo ThinkPad x120e Keyboard Replacement
  1. Lenovo ThinkPad x120e Keyboard Replacement, Battery: step 1, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop upside down and locate the battery latches under the battery.
    • Place your thumbs on both latches and push the latch inwards.
    • With your thumbs still on the latches, slide the battery out of the laptop.
    • To install a new battery, simply slide the battery back in the slot. Then, check if both battery latches are locked
  2. Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 1 of 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 2 of 3 Lenovo ThinkPad x120e Keyboard Replacement, Back Cover: step 2, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws that are securing the bottom cover.
    • Remove the backplate carefully, making sure not to bend the cover.
  3. Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: step 3, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 4 mm retaining screws located on the battery slot.
  4. Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 1 of 3 Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 2 of 3 Lenovo ThinkPad x120e Keyboard Replacement: step 4, image 3 of 3
    • Flip the laptop back over, showing the keyboard.
    • Using an opening tool, pry open the keyboard starting from the top left. Work your way around until you are able to loosely lift the keyboard.
    • You should see two ribbon wires located beneath the keyboard once you are done.
  5. Lenovo ThinkPad x120e Keyboard Replacement: step 5, image 1 of 2 Lenovo ThinkPad x120e Keyboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Pull on the black tabs above both ribbon wires using tweezers upwards.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Remove both ribbon wires.
    • Remove the keyboard from the laptop.
Jacob Fronzaglia
787 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 637
