Introduction
Having a problem with Hard Disk in your Lenovo X240 ? Follow along while we show you how to get it replaced! All you need is your iFixit Toolkit.
Flip the laptop upside down as shown in the photo.
Remove the back cover using the opening tools.
As mentioned below, if there is an SD card in the reader, the cover will not come off, so make sure to remove it.
9 other people completed this guide.
5 Comments
Hello, i think you forgot to disconnect internal battery first before you replace something
That is true, that'd been a much safer way to do it.
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
If you have an SD card in the SD card reader make sure to remove it before trying to remove the case cover, otherwise it will not come off, and you risk damaging your motherboard if you force it.
