Shop the Holiday Gift Guide
Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
60
Past 30 Days:
258
All Time:
967
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to open the laptop to replace the Thermal Paste. This guide will also help you upgrade the SSD inside.
Parts
Tools
    1. Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, Opening the back panel: step 1, image 1 of 2 Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, Opening the back panel: step 1, image 2 of 2
      • Unscrew all screws holding the back panel in place.
      • Use a prying tool to remove the back panel.
      Ask FixBot
    2. Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 1 of 3 Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 2 of 3 Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, Changing the thermal paste: step 2, image 3 of 3
      • Unscrew the 4 screws holding the CPU heatsink and disconnect the fan.
      • Clean the old thermal paste from both the cooler and the CPU.
      • Use isopropyl alcohol and cotton swabs or paper towel, but be careful not to press too hard on the CPU.
      • It's also recommended to use compressed air to remove any dust in the laptop and the fan.
      • Use only enough thermal paste to cover a portion of the pad. Use a spreader if you have one.
      • The thermal paste will apply evenly after you tighten the heatsink.
      • Place the heatsink back into the unit carefully and tighten the screws in an "X" pattern to ensure even pressure. Don't forget to plug in the fan cable.
      Ask FixBot
    3. Lenovo ThinkPad X13 Gen 1 Thermal Paste Replacement, SSD upgrade: step 3, image 1 of 1
      • Once you have the back cover opened, it is a good opportunity to upgrade the SSD.
      Ask FixBot
Author
with
Simeon Brankov
10,542 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 60
Past 30 Days: 258
All Time: 967
