Introduction
If your notebook’s battery life is no longer sufficient when unplugged, replacing the battery may help.
This guide shows you how to replace the battery in your Lenovo ThinkPad X1 Yoga (3rd Gen, model number: 20LES09800).
Before you begin:
- Back up your (most important) data before starting the replacement.
- Discharge the battery to below 25% to reduce the risk of dangerous overheating if damaged.
- If the battery is swollen, be sure to take appropriate safety precautions.
Reboot your laptop.
On the Lenovo boot-screen, first press the Enter key and then press F1 in the Startup Interrupt Menu that appears afterwards to enter the BIOS.
Use the left/right arrow keys to navigate to the Config section.
Use the up/down arrow keys to navigate to the Power option and press Enter .
Use the up/down arrow keys to navigate to Disable Built-in Battery and press Enter.
Confirm disabling with Enter.
Loosen the eight Phillips #0 screws on the underside of the case.
Carefully pry the case cover off the laptop.
Pull the white plug of the speaker cable (towards the battery) out of the socket.
Carefully peel the black protective film covering the battery connector away from the film underneath.
Disconnect the black battery connector from the port; the easiest way to do this is with an opening tool
Remove the six Phillips #0 screws located on the two speakers to the left and right of the battery.
Remove the seventh Phillips #0 screw located at the bottom of the battery.
Now lift the battery at the bottom edge and remove it (along with the speakers), and remove the speakers.
To turn the laptop on after reassembly, you need to plug it in.
Afterwards, remember to calibrate your laptop to the new battery.
Dispose of your e-waste properly.
If the repair didn’t go as planned, check out these basic repair guides, or ask for help in the forum.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
