Lenovo ThinkPad T500 Speaker Replacement
  1. Lenovo ThinkPad T500 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Remove the eight 14mm screws using the Phillips #0 Screwdriver.
  2. Lenovo ThinkPad T500 Speaker Replacement: step 2, image 1 of 1
    • Lift the palm rest panel up.
    • Be sure to lift the panel slowly; there is a ribbon cable attached to the bottom.
  3. Lenovo ThinkPad T500 Speaker Replacement: step 3, image 1 of 1
    • Use the spudger to disconnect the ribbon cable.
  4. Lenovo ThinkPad T500 Speaker Replacement: step 4, image 1 of 1
    • With the panel disconnected, lift the keyboard.
    • As with the panel, lift the keyboard slowly; there is a ribbon cable attached to the bottom.
  5. Lenovo ThinkPad T500 Speaker Replacement: step 5, image 1 of 1
    • Disconnect the ribbon cable with the spudger.
  6. Lenovo ThinkPad T500 Speaker Replacement: step 6, image 1 of 2 Lenovo ThinkPad T500 Speaker Replacement: step 6, image 2 of 2
    • Remove the keyboard and the panel.
    • Using the Phillips #0 Screwdriver, remove the three 3 mm screws that are at the bottom sides and near the top-left of the speaker cover.
    • Disconnect the orange and blue cables next to the left side of the speaker cover.
  7. Lenovo ThinkPad T500 Speaker Replacement: step 7, image 1 of 1
    • Remove the speaker cover by carefully pulling up and towards you.
  8. Lenovo ThinkPad T500 Speaker Replacement: step 8, image 1 of 1
    • Remove the four 3mm screws on the speakers with the Phillips #0 Screwdriver.
  9. Lenovo ThinkPad T500 Speaker Replacement: step 9, image 1 of 2 Lenovo ThinkPad T500 Speaker Replacement: step 9, image 2 of 2
    • Using the spudger, lift the tape over the right speaker's wires.
    • Although the right speaker is unscrewed, it can't be removed from the laptop yet!
  10. Lenovo ThinkPad T500 Speaker Replacement: step 10, image 1 of 2 Lenovo ThinkPad T500 Speaker Replacement: step 10, image 2 of 2
    • Detach the blue and orange cables from the left speaker's clamps.
  11. Lenovo ThinkPad T500 Speaker Replacement: step 11, image 1 of 3 Lenovo ThinkPad T500 Speaker Replacement: step 11, image 2 of 3 Lenovo ThinkPad T500 Speaker Replacement: step 11, image 3 of 3
    • Locate the plug in the middle of the laptop that connects both the left and right speakers.
    • Use the spudger to unplug the speaker wires.
  12. Lenovo ThinkPad T500 Speaker Replacement: step 12, image 1 of 1
    • Remove the speakers.
Matthew Fajardo
519 Reputation
0 Guides authored
Cal Poly, Team 5-7, Maness Spring 2015 Member of Cal Poly, Team 5-7, Maness Spring 2015
CPSU-MANESS-S15S5G7
4 Members
0 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,195
