Lenovo ThinkPad T490 SSD Replacement
    1. Lenovo ThinkPad T490 SSD Replacement, Base Plate: step 1, image 1 of 1
      • Loosen the screws from the base plate.
      • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
      • These screws are captive - they will not fully come out after being unscrewed.
      Ask FixBot
    2. Lenovo ThinkPad T490 SSD Replacement: step 2, image 1 of 1
      • Insert the iFixit opening tool into the space between the base plate and the chassis.
      • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
      Ask FixBot
    3. Lenovo ThinkPad T490 SSD Replacement: step 3, image 1 of 1
      • Grab the edge of the cover and lift the cover away from you.
      • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
      Ask FixBot
    1. Lenovo ThinkPad T490 SSD Replacement, SSD: step 4, image 1 of 2 Lenovo ThinkPad T490 SSD Replacement, SSD: step 4, image 2 of 2
      • Grab the battery pull-tab at the top of the connector plugin.
      • Pull the connector straight out in the direction toward the cable.
      Ask FixBot
    2. Lenovo ThinkPad T490 SSD Replacement: step 5, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the 3.7 mm Phillips screw securing the SSD.
      Ask FixBot
    3. Lenovo ThinkPad T490 SSD Replacement: step 6, image 1 of 1
      • Disconnect the SSD from its socket.
      • If it requires excess force to remove, wiggle side to side while pulling.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
1 Guide Comment
Strongly recommend reading Lenovo's own "T490 and P43s Hardware Maintenance Manual", particularly section "1020 Base cover assembly" which gives a recommended order for prying open the clips. It's pretty easy to apply too much pressure in the wrong place and snap a clip, especially now the plastics in these laptops are getting older.
(It's also possible to remove power by changing a setting in the BIOS instead of unplugging the battery, Lenovo's guide also explains how to do this.)
projectgus - Reply Share
Past 24 Hours: 10
Past 7 Days: 65
Past 30 Days: 216
All Time: 3,612
