Shop the Holiday Gift Guide
Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
9
Past 7 Days:
51
Past 30 Days:
180
All Time:
2,218
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide covers how to replace the fan for the Lenovo ThinkPad T490. You should replace your laptop fan if you notice unusual noise, overheating and cooling problems. The fan in your laptop is essential because it is responsible for keeping the laptop cool, keeping up with performance, prevent overheating and maintaining your laptop lifespan. Before replacing your fan, you should backup your data and power off and unplug your computer.
Parts
Tools
    1. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Base Plate: step 1, image 1 of 1
      • Loosen the screws from the base plate.
      • Using a Philips #1 screwdriver fully loosen the six screws on the back cover.
      • These screws are captive - they will not fully come out after being unscrewed.
      Ask FixBot
    2. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: step 2, image 1 of 1
      • Insert the iFixit opening tool into the space between the base plate and the chassis.
      • Glide the tool along the perimeter of the case in order to release the clips holding the case and chassis together.
      Ask FixBot
    3. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: step 3, image 1 of 1
      • Grab the edge of the cover and lift the cover away from you.
      • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
      Ask FixBot
    1. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement, Fan and Heat Sink Assembly: step 4, image 1 of 1
      • Use a Philips #1 screwdriver to loosen the five captive screws that secure the heat sink.
      Ask FixBot
    2. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: step 5, image 1 of 1
      • Disconnect the fan connector from its motherboard socket.
      Ask FixBot
    3. Lenovo ThinkPad T490 Fan and Heat Sink Assembly Replacement: step 6, image 1 of 1
      • Gently lift the fan and heat sink assembly up and out of the chassis.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
Author
with
Reiona Silas
153 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 51
Past 30 Days: 180
All Time: 2,218
