Lenovo ThinkPad T420s Keyboard Replacement
  1. Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: step 1, image 1 of 2 Lenovo ThinkPad T420s Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Flip your laptop over so the bottom is facing up.
    • Remove the memory panel by removing two black 5mm screws using the Phillips #0.
    • Remove the memory panel.
  2. Lenovo ThinkPad T420s Keyboard Replacement: step 2, image 1 of 1
    • Remove the two 5mm screw using the Phillips #0 screwdriver.
    • Flip the laptop back over and open it.
  3. Lenovo ThinkPad T420s Keyboard Replacement: step 3, image 1 of 3 Lenovo ThinkPad T420s Keyboard Replacement: step 3, image 2 of 3 Lenovo ThinkPad T420s Keyboard Replacement: step 3, image 3 of 3
    • Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
    • The best place to push is on the frame of the keyboard by the power button.
    • Using the metal spudger, lift and slide out the keyboard.
    • When lifting the keyboard do not remove it completely because a cable will still be connected to the laptop.
  4. Lenovo ThinkPad T420s Keyboard Replacement: step 4, image 1 of 1
    • Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
11 other people completed this guide.
Alex Cabrera
650 Reputation
2 Guides authored
Cal Poly, Team 6-13, Maness Spring 2015 Member of Cal Poly, Team 6-13, Maness Spring 2015
CPSU-MANESS-S15S6G13
4 Members
5 Guides authored
6 Comments
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
Keith Cloward - Reply
The steps are almost exactly the same though - I've performed them on my own T420. This guide is for the T420s. Just remove the memory panel with the single screw on the base of the laptop, remove the screw with the keyboard emblem next to it, and follow the keyboard removal steps in this guide.
Toby Jones -
you do know this guide was made for the T420s? it literally says so on the guide. take a moment to read my friend.
the bongo guy -
I just did this, in combination with this: https://support.lenovo.com/us/en/solutio...
Was pretty easy and working great. I am bit intimidated opening up a laptop or PC, but the “Easy” rating on this gave me the idea to try. Glad I did.
Jay Stokes - Reply
Thanks for your post Jay, the link was not valid any more but i went on that site and looked for the correct Maintenance Manual which helped me complement this guide while changing my keyboard. Here everyone with Lenovos can get this kind of Manuals which are official, very complete, and explanatory with good graphics of the procedures and parts: https://download.lenovo.com/eol/index.ht...
Javier -
I have disassemble and assembled all the keys on the keyboard but I’m having trouble assembling the muse buttons, can anybody help me
Vegard - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 64
All Time: 33,511
