Introduction
Follow this guide to replace a dead or worn-out battery in your Lenovo ThinkPad T16 Gen 3 laptop.
The Lenovo model number for the battery is L23M4P70 for the 52.5Wh model and L23M4P71 or L23M4P72 for the 86Wh model.
Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
Insert your fingernail or an opening pick into the gap between the base cover and keyboard deck, next to one of the screen hinges.
Pry up the base cover until the clips unfasten.
Grasp the base cover along the screen hinge edge and lift slowly to unfasten the remaining clips.
Lift and remove the base cover.
Use a Phillips screwdriver to fully loosen the two captive screws securing the battery connector.
Lift the edge of the battery with the connector to disconnect it.
Remove the battery
Slide the plastic tabs on the long edge of the battery into their recesses in the frame.
Lower the battery into place so the connector goes over its socket.
Calibrate your newly installed battery after completing this guide.
1 Guide Comment
5B11H56411 is the part number on Lenovo.com for the 86wh battery fyi
