Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement
  1. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
  2. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Loosen the base cover screws: step 2, image 1 of 2 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Loosen the base cover screws: step 2, image 2 of 2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the base cover: step 3, image 1 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the base cover: step 3, image 2 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the base cover: step 3, image 3 of 3
    • The base cover is still lightly clipped to the laptop.
    • Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
    • Repeat at the top-left corner.
  4. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 4, image 3 of 3
    • Slowly lift the hinge edge of the base cover until the remaining clips release.
    • Remove the base cover.
    • During reassembly, align the base cover's bottom edge tabs with the laptop, then lay the cover in place. Press around the perimeter to clip the base cover to the laptop.
  5. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Disconnect the battery: step 5, image 1 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Disconnect the battery: step 5, image 2 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use your fingers to squeeze the two latches on either side of the battery connector.
    • While squeezing the latches, lift the top edge of the battery up.
  6. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the battery: step 6, image 1 of 2 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the battery: step 6, image 2 of 2
    • Remove the battery.
  7. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the USB-C port bracket: step 7, image 1 of 1
    • Use a Phillips screwdriver to loosen the three captive screws securing the USB-C port bracket.
  8. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 8, image 1 of 2 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 8, image 2 of 2
    • Use tweezers or your fingers to lift and remove the USB-C port bracket.
  9. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the USB-C ports: step 9, image 1 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the USB-C ports: step 9, image 2 of 3 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement, Remove the USB-C ports: step 9, image 3 of 3
    • Lift the front edge of the USB-C port closest to the hinge.
    • Slide the USB-C port out of its socket and remove it.
  10. Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 10, image 1 of 2 Lenovo ThinkPad T14 Gen 7 USB-C Port Replacement: step 10, image 2 of 2
    • Repeat the procedure with the second USB-C port.
    • During reassembly, install this USB-C port first.
Arthur Shi
329,152 Reputation
810 Guides authored
0 Guide Comments
Past 24 Hours: 21
Past 7 Days: 121
Past 30 Days: 590
All Time: 1,729
