Lenovo ThinkPad T14 Gen 7 Fan Replacement
  1. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • For your safety, discharge your battery below 25% before disassembling your laptop. A charged battery may catch fire if damaged. If your battery is swollen, take appropriate precautions.
    • Completely shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
  2. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Loosen the base cover screws: step 2, image 1 of 2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Loosen the base cover screws: step 2, image 2 of 2
    • Use a Phillips screwdriver to fully loosen the seven captive screws securing the base cover.
  3. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: step 3, image 1 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: step 3, image 2 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the base cover: step 3, image 3 of 3
    • The base cover is still lightly clipped to the laptop.
    • Use your fingers to grab and lift the top-right corner of the base cover near the hinge.
    • Repeat at the top-left corner.
  4. Lenovo ThinkPad T14 Gen 7 Fan Replacement: step 4, image 1 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement: step 4, image 2 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement: step 4, image 3 of 3
    • Slowly lift the hinge edge of the base cover until the remaining clips release.
    • Remove the base cover.
    • During reassembly, align the base cover's bottom edge tabs with the laptop, then lay the cover in place. Press around the perimeter to clip the base cover to the laptop.
  5. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: step 5, image 1 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: step 5, image 2 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Disconnect the battery: step 5, image 3 of 3
    • Use your fingers to squeeze the two latches on either side of the battery connector.
    • While squeezing the latches, lift the top edge of the battery up.
  6. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the battery: step 6, image 1 of 2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the battery: step 6, image 2 of 2
    • Remove the battery.
  7. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: step 7, image 1 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: step 7, image 2 of 3 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Detach the fan: step 7, image 3 of 3
    • Use tweezers or your fingernails to gently push the fan connector out of its socket to disconnect it.
  8. Lenovo ThinkPad T14 Gen 7 Fan Replacement: step 8, image 1 of 1
    • Use a Phillips screwdriver to loosen the three captive screws securing the fan.
  9. Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the fan: step 9, image 1 of 2 Lenovo ThinkPad T14 Gen 7 Fan Replacement, Remove the fan: step 9, image 2 of 2
    • Lift and remove the fan.
Arthur Shi
329,152 Reputation
810 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 150
All Time: 566
