Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement
  1. Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement, Bottom Panel: step 1, image 1 of 3 Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement, Bottom Panel: step 1, image 2 of 3 Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement, Bottom Panel: step 1, image 3 of 3
    • Turn off your laptop completely before starting the disassembly process.
    • Use a Phillips #1 screwdriver to remove
    • The top two 6.8 mm corner screws
    • Four 5.8 mm-long screws
    • Make sure to keep the different length screws separate after taking them out for easier reassembly.
  2. Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement: step 2, image 1 of 3 Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement: step 2, image 2 of 3 Lenovo ThinkPad T14 Gen 1 Bottom Panel Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to pry the bottom panel.
    • Insert the end of the opening tool into the seam between the bottom and top cover.
    • Slide the opening tool around the edge of the bottom panel to release the clips holding them together.
    • The popping sounds during this process is normal.
    • Gently remove the bottom panel.
    • Using too much force can break the plastic clips securing the bottom panel.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 47
Past 30 Days: 129
All Time: 214
