Lenovo ThinkPad L390 Wi-Fi Card Replacement
  1. Lenovo ThinkPad L390 Wi-Fi Card Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 Wi-Fi Card Replacement, Lower Case: step 1, image 2 of 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
  2. Lenovo ThinkPad L390 Wi-Fi Card Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Insert an opening tool in the gap between the lower case and the chassis.
    • Pry around the entire perimeter of the lower case until it fully releases.
    • Lift the lower case up and off.
  3. Lenovo ThinkPad L390 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 1
    • Remove the single 5 mm Phillips screw that secures the Wi-Fi card.
  4. Lenovo ThinkPad L390 Wi-Fi Card Replacement: step 4, image 1 of 2 Lenovo ThinkPad L390 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Use the pointed end of a spudger to lift and disconnect the two Wi-Fi card coaxial cables.
  5. Lenovo ThinkPad L390 Wi-Fi Card Replacement: step 5, image 1 of 1
    • Gently pull the Wi-Fi card directly out of its socket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Konstantin Nosov
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 36
All Time: 221
