Lenovo ThinkPad L390 Trackpad Replacement
  1. Lenovo ThinkPad L390 Trackpad Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 Trackpad Replacement, Lower Case: step 1, image 2 of 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
  2. Lenovo ThinkPad L390 Trackpad Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 Trackpad Replacement: step 2, image 2 of 2
    • Insert an opening tool in the gap between the lower case and the chassis.
    • Pry around the entire perimeter of the lower case until it fully releases.
    • Lift the lower case up and off.
  3. Lenovo ThinkPad L390 Trackpad Replacement, Lenovo ThinkPad L390 Battery Disconnection: step 3, image 1 of 1
    • Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
    • Do not pull on the wires.
  4. Lenovo ThinkPad L390 Trackpad Replacement, Battery Removal: step 4, image 1 of 2 Lenovo ThinkPad L390 Trackpad Replacement, Battery Removal: step 4, image 2 of 2
    • Remove the five 4mm #00 phillips screws from the battery.
    • Lift the battery up with the opening tool.
  5. Lenovo ThinkPad L390 Trackpad Replacement: step 5, image 1 of 2 Lenovo ThinkPad L390 Trackpad Replacement: step 5, image 2 of 2
    • Lift the black tab up to access the trackpad connector.\
    • Gently pull the trackpad connector down to detach the trackpad from the motherboard.
  6. Lenovo ThinkPad L390 Trackpad Replacement: step 6, image 1 of 3 Lenovo ThinkPad L390 Trackpad Replacement: step 6, image 2 of 3 Lenovo ThinkPad L390 Trackpad Replacement: step 6, image 3 of 3
    • Remove the four 1mm #00 phillips screws from the copper cover.
    • Lift the bottom of the computer to access the detached trackpad
  7. Lenovo ThinkPad L390 Trackpad Replacement: step 7, image 1 of 1
    • Congratulations, you've removed the trackpad.
To reassemble your device, follow these instructions in order.
mariiaamacedo
150 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 32
All Time: 220
