Lenovo ThinkPad L390 SSD Replacement
  1. Lenovo ThinkPad L390 SSD Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 SSD Replacement, Lower Case: step 1, image 2 of 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
  2. Lenovo ThinkPad L390 SSD Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 SSD Replacement: step 2, image 2 of 2
    • Insert an opening tool in the gap between the lower case and the chassis.
    • Pry around the entire perimeter of the lower case until it fully releases.
    • Lift the lower case up and off.
  3. Lenovo ThinkPad L390 SSD Replacement, Lenovo ThinkPad L390 Battery Disconnection: step 3, image 1 of 1
    • Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
    • Do not pull on the wires.
  4. Lenovo ThinkPad L390 SSD Replacement, SSD: step 4, image 1 of 2 Lenovo ThinkPad L390 SSD Replacement, SSD: step 4, image 2 of 2
    • Remove the 3 mm screw from that secures the SSD with a Phillips #1 screwdriver.
  5. Lenovo ThinkPad L390 SSD Replacement: step 5, image 1 of 2 Lenovo ThinkPad L390 SSD Replacement: step 5, image 2 of 2
    • Use a screwdriver to pop the SSD slightly off the motherboard.
    • Parts like the SSD card are fragile so make sure to take care when handling them.
  6. Lenovo ThinkPad L390 SSD Replacement: step 6, image 1 of 3 Lenovo ThinkPad L390 SSD Replacement: step 6, image 2 of 3 Lenovo ThinkPad L390 SSD Replacement: step 6, image 3 of 3
    • Pinch and pull the SSD card to remove it from its connecting port on the motherboard.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 92
All Time: 1,199
