Lenovo ThinkPad L390 Fan and Heat Sink Replacement
  1. Lenovo ThinkPad L390 Fan and Heat Sink Replacement, Lower Case: step 1, image 1 of 2 Lenovo ThinkPad L390 Fan and Heat Sink Replacement, Lower Case: step 1, image 2 of 2
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Lay the device down with the lower case facing up.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Unscrew the nine 5 mm Phillips #00 screws that secure the lower case.
  2. Lenovo ThinkPad L390 Fan and Heat Sink Replacement: step 2, image 1 of 2 Lenovo ThinkPad L390 Fan and Heat Sink Replacement: step 2, image 2 of 2
    • Insert an opening tool in the gap between the lower case and the chassis.
    • Pry around the entire perimeter of the lower case until it fully releases.
    • Lift the lower case up and off.
  3. Lenovo ThinkPad L390 Fan and Heat Sink Replacement, Lenovo ThinkPad L390 Battery Disconnection: step 3, image 1 of 1
    • Use your fingernails or two opening tools to gently "walk" the battery connector directly out of its socket.
    • Do not pull on the wires.
  4. Lenovo ThinkPad L390 Fan and Heat Sink Replacement, Fan and Heat Sink: step 4, image 1 of 1
    • Remove the four 4 mm Phillips #00 screws that secure the heat sink.
    • Remove the 6 mm Phillips #00 screw that secures the fan.
    • Do not begin to remove the fan just yet.
  5. Lenovo ThinkPad L390 Fan and Heat Sink Replacement: step 5, image 1 of 2 Lenovo ThinkPad L390 Fan and Heat Sink Replacement: step 5, image 2 of 2
    • Grip the fan/heat sink assembly from both sides and lift it up and out of the chassis.
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 57
All Time: 524
