Lenovo Tab 2 A8 Motherboard Replacement
  1. Lenovo Tab 2 A8 Motherboard Replacement, Removing the Back Panel: step 1, image 1 of 3 Lenovo Tab 2 A8 Motherboard Replacement, Removing the Back Panel: step 1, image 2 of 3 Lenovo Tab 2 A8 Motherboard Replacement, Removing the Back Panel: step 1, image 3 of 3
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Motherboard Replacement: step 2, image 1 of 3 Lenovo Tab 2 A8 Motherboard Replacement: step 2, image 2 of 3 Lenovo Tab 2 A8 Motherboard Replacement: step 2, image 3 of 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Lenovo Tab 2 A8 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Lenovo Tab 2 A8 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
    • Because the screws are small, it is a good idea to remove them with a pair of tweezers.
  4. Lenovo Tab 2 A8 Motherboard Replacement: step 4, image 1 of 3 Lenovo Tab 2 A8 Motherboard Replacement: step 4, image 2 of 3 Lenovo Tab 2 A8 Motherboard Replacement: step 4, image 3 of 3
    • Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
    • With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
    • With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
    • The strip connecting the screen to the motherboard is firmly in place and may require some careful use of strength to unplug it.
  5. Lenovo Tab 2 A8 Motherboard Replacement: step 5, image 1 of 1
    • Remove the motherboard by lifting the top edge and pulling outward to free it from the small tabs that hold it in place.
    • The small tabs can be broken if the motherboard is pried up too forcefully.
    • The button tabs are fastened to the motherboard by a small adhesive strip. Take care in removing the motherboard to avoid tearing the wires.
3 other people completed this guide.
2 Comments
Love the pictures . GREAT instructions!
I have a Lenovo TB3-850F tablet.
Now, can I upgrade the RAM from 1 gig to 2 gig or 4 gig? The picture procedure would be great if this is possible.
Thanks,
Lance Houser - Reply
[|hello, can you please help me.Because I loose the connection between display and balance board. I don't know what to do. So you kindly help us.]
Abhiram - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 2,892
