Introduction
If your tablet does not start properly or freezing...
If your tablet is stuck on Lenovo logo or...
If you have "Too many patterns attempts"...
If you forgot you password and can't log in with your google account...
If you want to erase data from the device...
Annotation!!! You will loose all your data!!!
Video Overview
First of all you can try soft reset from the reset switch. This method does not delete the data from the tablet.
Now - hardware reset:
Switch off the tablet.
Press and hold at the same time Volume UP and Power keys.
When the System Recovery screen appears use the Volume Up/Down keys for navigation and the Power On key for OK.
Choose "wipe data / factory reset", "Yes -- delete all user data", "reboot system now".
I need to download the file to reset in computer
How long it takes to reboot and In my tablet I clicked on reboot system now and a Lenovo logo was come and go off I don't know what was happening. I was waiting for 1 hours now tell me what would I need to do
My system recovery screen goes off just as soon as I take my fingers off the two buttons, up and volume
On my Lenovo tablet, my screen to reboot will not stay on for me to do a hard
I'm doing everything like it said and when I keep press on the both bottoms and is not stay on to press ok for restat is going back to login
I’ve pressed quite long, and nothing happen. It doesnt work
C’est fait mais j’arrive sur une fenĂªtre qui me demande de m’identifier avec mon compte Google. Je le fais mais sans rĂ©sultat
That's all.
please will it keep long on the first step... when u press the volume up and power keys
That didn't work with my tablet
After rebooting it asked for the language
I entered English united states
Then it shows just a sec and keeps on loading
47 other people completed this guide.
36 Comments
If device is connected to charger that button combination doesn't work. It goes to hardware test menu.
How to reser chinese language lenova phone
With Chinese phones, you do not need to use other options, and there is no confirmation. The wipe simply starts, and completes by wiping your phone. Read more - http://www.gogorapid.com/how-to-reset-ch...
My lenovo a 1000 idea tab's display is gone....no bottom in work...how to reset or fix it
my lenovo s850 is on meta mode when i press vol down + power button and nothing appear when i press vol up + power button.. the thing is i've tried many button sequence but i just cat get into reset mode or cynogen mode.. :(
My lenovo tab isnt working until it went to some sort of menu using volume buttons but then i actually pressed something and it went to a screen saying "Now send the package you want to apply to the device using adb sideload <filename>" how do i go back to the reboot menu
i also tried same but i have not gotten any solution to mine too. what next please. i am missing my tab already
sana gumana sa akin........
my lenovo tab 2 a7-30hc also has the problem. I did the same as what the video showed but it's still stuck on the lenovo logo. before the whole thing happened, my tablet was lagging so i thought about fixing it by uninstalling some apps until i pressed 'force stop' on an app. the battery got drained and the tab shut down. when i recharged it and attempted to turn it on, it was stuck on the logo. i waited for several minutes but its still the same. after that, i researched about how to fix it and i found this. I did it with my tab but nothing changed. it's still stuck. what should i do? the tab's not really mine. i just borrowed it from my father. if he finds out about what happened with his tablet, he might not talk to me for some time.. please answer me.
My Lenovo tab shows encryption error and shows reset option,while the option isn't working..I tried for hard reset..that won't work too..and finally I tried to download new software..the tab isn't accepting it.
IS THERE ANY SOLUTION????
I reset my lenovo to factory reset then it asks for email that was previously sync to device. I type in email and password and it then goes back to asking me for email that was synced previously to device. And round and round it goes. How can i make tis work again.
robyntomlinson59@gmail.com
Were you ever able to get it to login? Mine is doing the same thing
I am having the same sign in problem as Robyn with my Lenovo tablet
Wich Chinese words do i push
my lenovo tab is showing nothing on the screen after factory reset
Did that now will kot go past lenovo screen saver?
For anyone who may be having trouble with this fix please know that the volume up button is the button you use to select each line. So instead of hitting the power button when you have "wipe data/factory reset" highlighted press the volume up key to select and follow from there. Hope that change to the directions helps some of you.
I used recovery mode to factory reset my tablet. After rebooting it asked for the language and I entered English united states then it shows just a sec
And keeps on loading
Can any one pl reply to my question above
loly of God so many
On my Lenovo tablet when I push the up and volume button at the same time, the page with the hard reset info won't stay on long enough for me to do a
When I hold up vol n power I only get recover, fastboot, normal. Tryed recover and still on normal screen asking for my pattern help please
Thnk u For information.. im from indonesia
Hi I have completed the factory reset then I went into Reboot system now but nothing happens my tablet is still stuck on the Lenevo logo and won't do anything . I have tried resetting several times also switchin off and restating but it still does not work !! Help ….
I have rooted my tablet and it won't start in recovery mode it just boot looped
I bought a lenovo tablet that is google locked and can't load my google account
after hard resat or wipe data lenovo tab not start atuck on lenovo logo. what to do help anyone.
Nickel !
Je vais pouvoir me resservir de ma tablette !
RĂ©initialisation d'usine
how do you do a software reset?
Z'Marion Perkins - Reply
