Introduction
If your trackpad stops working or has any performance issues, you can follow this guide to remove and replace it.
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the battery in the bottom right corner.
Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
2 other people completed this guide.
