Lenovo Ideapad 320-17IKB Hard Drive Replacement
  1. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 2, image 1 of 2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 2, image 2 of 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 3, image 1 of 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 4, image 1 of 2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 4, image 2 of 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Battery: step 5, image 1 of 2 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Battery: step 5, image 2 of 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 6, image 1 of 2 Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 6, image 2 of 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: step 7, image 1 of 3 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: step 7, image 2 of 3 Lenovo Ideapad 320-17IKB Hard Drive Replacement, Hard Drive: step 7, image 3 of 3
    • Disconnect the hard drive from the SATA slot by gently pulling the hard drive to the left.
  8. Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 8, image 1 of 3 Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 8, image 2 of 3 Lenovo Ideapad 320-17IKB Hard Drive Replacement: step 8, image 3 of 3
    • Use your hands to gently pull the edges at each corner away from the hard drive to remove the hard drive adapter.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 173
