Lenovo IdeaPad G500 Replacing the keyboard
  1. Lenovo IdeaPad G500 Replacing the keyboard, The Lock: step 1, image 1 of 1
    • First you have to release the "lock" for the battery. You can do this by simply pushing the two sliders in the direction of the arrows.
    • ATTENTION: The right slider does not lock, you have to hold it.
  2. Lenovo IdeaPad G500 Replacing the keyboard, Removal: step 2, image 1 of 1
    • Now you can pull the battery out and up. It might be a little tight, so feel free to use a little more force.
  3. Lenovo IdeaPad G500 Replacing the keyboard, The Screws: step 3, image 1 of 1
    • After the battery is removed, you can easily loosen the two screws shown using a Phillips screwdriver.
    • ATTENTION: Here is a guarantee seal! You have to break this to remove the back cover. Your warranty claims will therefore be lost! (Translator's note: This is not always true, check the law where you live.)
  4. Lenovo IdeaPad G500 Replacing the keyboard, Removing th Back Cover: step 4, image 1 of 1
    • Now you can easily slide off the back cover in the direction of the arrows.
    • You can then remove it by lifting upwards.
  5. Lenovo IdeaPad G500 Replacing the keyboard, The Lock: step 5, image 1 of 1
    • After you remove the back cover, you should see the three marked screws.
    • You must remove them.
  6. Lenovo IdeaPad G500 Replacing the keyboard, The clips: step 6, image 1 of 1
    • after the screws have been removed you can begin freeing the keybpard.
    • Note: the keyboard is held in the frame by ten clips. The clips are located at the points marked with red arrows.
  7. Lenovo IdeaPad G500 Replacing the keyboard, Prying: step 7, image 1 of 1
    • Now use a thin piece of sheet metal, a credit card or Jimmy (Ifixit tool) and gently push it into the slot between the frame and the keyboard. It"s best to start at the top right.
    • You can now pry very easily to lift the keyboard out of the clip. It"s best to insert another thin object in between after a clip has been released (so it doesn't slip back down).
  8. Lenovo IdeaPad G500 Replacing the keyboard, The Flex Cable: step 8, image 1 of 1
    • ATTENTION: Once you have freed the keyboard from the frame, you still need to disconnect the flex cable before you can remove it.
    • Use a small flat-head screwdriver and lift the lock of the plug. (The small gray strip)
    • You can then pull the cable out of the connector.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Daniel Kramp
1,269 Reputation
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 122
