Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement
  1. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement, Display Assembly: step 1, image 1 of 2 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement, Display Assembly: step 1, image 2 of 2
    • Remove any accessories such as the detachable keyboard from the device.
    • Power the device off by pressing and holding the power button for about three seconds.
  2. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 2, image 1 of 2 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 2, image 2 of 2
    • Insert a spudger into the ridge between the screen and the back of the device, creating a small gap.
    • Run the spudger along the edge of the screen and around the corners to separate the screen from the rest of the device.
    • Be careful not to use more force than necessary with the metal spudger or else the device could potentially be scratched.
    • Do not fully lift or pull the screen away from the device once it is loose because the internal connectors are still attached.
  3. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 3, image 1 of 3 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 3, image 2 of 3 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 3, image 3 of 3
    • Lift the small tab on the orange connector.
    • Separate the screen from the back of the device.
  4. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement, Speakers: step 4, image 1 of 2 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement, Speakers: step 4, image 2 of 2
    • Remove four 3 mm screws using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 5, image 1 of 2 Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 5, image 2 of 2
    • Disconnect the speaker by gently but firmly pulling the white connector directly from the device.
    • Remove the speaker.
    • Repeat for the left speaker.
    • The process is identical, except that on the left speaker, there are three 3 mm screws instead of four.
  6. Lenovo IdeaPad Duet 3 Chromebook 11Q727 Speakers Replacement: step 6, image 1 of 1
    • Repeat steps 4-7 for the left speaker, if needed.
    • The process is identical, except that on the left speaker, there are three 3mm screws as opposed to four.
Christian Reyes
150 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 153
