Introduction
Go to step 1 ↓Are your speakers not outputting the correct sound on your Lenovo IdeaPad 330-15IKB 81DE? Is there no sound at all? You may have excessively worn speakers or physically damaged speakers that need to be replaced. This guide will provide you with the necessary tools to efficiently and easily change your speakers to go back to enjoying the sound quality you are supposed to have.
Tools
Spudger4.9
Ensure the laptop is powered off.
Turn the device over so the bottom is facing up.
Remove the 13 6 mm screws from the bottom of the device using a Phillips #0 screwdriver.
Carefully glide a Jimmy along the seam of the casing.
Remove the back cover of the laptop.
Remove the three 6 mm screws from the tabs surrounding the battery using a Phillips #0 screwdriver.
Carefully separate the battery connector from the device using a spudger.
Lift the battery up and remove it from the device.
Remove the connector for the speakers from the motherboard using a spudger.
Gently lift the speakers from the device using a spudger.
Carefully lift the red wire from its dock along the bottom.
Remove the speakers from the device.
