Introduction
This guide is necessary for times when the trackpad is unresponsive and thought to be broken or damaged. Replacing the trackpad requires that you replace the entire keyboard and trackpad as a whole piece.
  1. It is recommended that you replace the entire keyboard and trackpad panel as a whole piece.
    • It is recommended that you replace the entire keyboard and trackpad panel as a whole piece.
    • Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Flip the laptop over.
  2. Remove the single Phillips #0 screw that is holding the CD drive in place.
    • Remove the single Phillips #0 screw that is holding the CD drive in place.
    • Pull out the CD drive.
    • Remove the single Phillips #0 screw that is holding down the battery and ram panel.
    • Remove the battery and ram panel.
    • To unplug the keyboard ribbon cable, flip up the black tab.
    • Pull the ribbon cable straight out.
    • Remove the 12 Phillips #0 screws that are holding the keyboard panel in place.
    • One of the screws is hiding under a sticker.
    • Flip the laptop back over.
    • Using a plastic spudger, pry between the keyboard panel and back panel layer along the entirety of the seam.
    • Remove the keyboard panel.
    • If the panel feels like it is breaking, there is probably still a screw attached.
Richard
270 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 72
All Time: 738
