1. Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Open Laptop between 90 to 130 degrees.
  2. Use the blue plastic spudger to pry the screen frame away from the screen. Use your fingers to finish removing the screen frame. Gently pull the screen frame out by tilting it forward and pulling up until it is removed.
    • Use the blue plastic spudger to pry the screen frame away from the screen.
    • Use your fingers to finish removing the screen frame.
    • Gently pull the screen frame out by tilting it forward and pulling up until it is removed.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Remove the 4 Phillips #0 screws at the 4 corners of the screen.
    • Remove the 4 Phillips #0 screws at the 4 corners of the screen.
  5. Slowly lean screen forward away from the outside cover.
    • Slowly lean screen forward away from the outside cover.
  6. Use needle nose tweezers to carefully detach the sticker from the bottom of the screen that is holding the webcam wires in place. Pull the screen out. Pull the screen out.
    • Use needle nose tweezers to carefully detach the sticker from the bottom of the screen that is holding the webcam wires in place.
    • Pull the screen out.
2 other people completed this guide.
Amanda Quinn
143 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 44
All Time: 795
